Post processor add total number of work offsets used in the beginning of the program?
CuttingEdgeManufacturing
how hard would this be to do? I use the Haas posts, and a milltronics post from autodesk. Basically want to spell out to setup guys how many offsets we are using in a program. I have it on my setup sheet already but as we all know things change very quickly in the manufacturing world, so i would like a final check in the program that says what the # of offsets its.
Replies (7)
Garrett_Wade
While I don't disagree this could be nice, in the meantime you could try adding this info to the comment field when you post so it shows at the top of the program.
thanks for the input. I had not considered that. things change alot here. we have some jobs we repeat often, and each time we run them we just run however many offsets we can(based on vises in the machine) so i am always changing my programs..
will take this into consideration!
serge.quiblier
Hello @CuttingEdgeManufacturing
It can be done in the post programmatically.
We need to browse the section available in the programs (i.e more or less the toolpaths), and list the wcs used.
To be smart, we need to add the wcs only once in our list.
Here is a small code doing this:
var wcsArray = new Array(); // dynamic empty array
function uniquelyAddToArray(arrayVar, arrayValue) {
  if (arrayVar.indexOf(arrayValue) < 0) { // if the value does not exist, add it
    arrayVar.push(arrayValue);
function onOpen() {
  var wcsRead;
  var numberOfSections = getNumberOfSections();
  for (var i = 0; i < numberOfSections; ++i) {  // loop thru the section
    var section = getSection(i);
    var sectionWcs = section.wcs;  // extract the wcs number
    uniquelyAddToArray(wcsArray, sectionWcs);
  var wcsNumber = wcsArray.length;  // get the size of the array = number of unique wcs used in the program
  writeln(wcsNumber);
You can grab the interesting part and throw them where ever you need.
Cheers.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
can this be added in literally anywhere in the post? I'm familiar with C# which this is not from what I can tell. but it appears the functions can be placed anywhere I believe. looks like the onOpen() function would just run at runtime, so it shouldn't quite matter where it is placed?
serge.quiblier
Hi @CuttingEdgeManufacturing
The variable definition for wcsArray should be placed in the global section, i.e for javascript anywhere between two functions bodies. This can be at the begining of the post when we are defining the format, variables...
It can be defined between two functions, before, or after the onOpen, javascript will find it as long at it's not inside another function body.
You can add it for example before the onOpen function.
Same consideration for the function uniquelyAddToArray.
And the code from var wcsRead; to var wcsNumber = wcsArray.length; can be added somewhere at the start of the onOpen function, eventually as in my example, at the very top of the function.
Cheers.
Serge.Q
cam.autodesk.com
Well, it at least posted. I dont think its quite right just yet. but i have a good start.
It posted what i think to be the "WCS offset" textbox value in the 3rd setup tab. Ill need to do the number of instances i think instead. and wrap it in parantheses.
serge.quiblier
The array will contain the wcs index, but the variable wcsNumber will contain the number of wcs used in the program thru the differents sections.
It will be counting the number of differents values defined here
Cheers.
Serge.Q
cam.autodesk.com
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
