Fusion Manufacture
Post Processing to Takisawa CNC Lathe TCN-2100CM L6
4 REPLIES 4
geofani_deni
116 Views, 4 Replies
Hi everyone, i would like to find Post Pro for Takisawa CNC Lathe TCN-2100CM L6. The fusion post library doesn’t have it so I thought I would check and maybe could find in here!. Thank you.
4 REPLIES 4
geofani_deni
in reply to: geofani_deni
Is there any Specialist CAD/CAM in this forum please help. Thank you.
a.laasW8M6T
Hi
You should be able to use this post processor
It may need some modification to work with your machine but it would be worth trying out to start with.
If you need post modifications you can reach out to one of the partners founder here:
https://customersuccess.autodesk.com/partners/search?search=&solutions%5B%5D=Fusion%20360&services%5...
You can filter by location to Find one in your area
geofani_deni
in reply to: a.laasW8M6T
Hi @a.laasW8M6T , thank you for your answer and sharing. I have used that post before and yes it requires some slight modifications to the head and end of the nc code. I will check the link you shared. Thank you very much.
CNC_Lee
@geofani_deni
If the generic posts are not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Message me if I can be of further assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
