Fusion Manufacture
Post-processing Fanuc A-T14 Ifb
6 REPLIES 6
tormode
179 Views, 6 Replies
Hello
I am looking for a post-processor to go with a Fanuc A-T14 Ifb.
The unit is stewing in our university lab where no one has the skill to create these files/dataset.
I am very new to F360 with no prior cnc programming skills. I also know that the uni payed a third-party to produce the post-processor for the last cad the used, so I am not assuming the information I need is free.
Anyone know where to start looking for this type of data?
Br, Tmod
Labels (6)
6 REPLIES 6
programming2C78B
in reply to: tormode
Cant you start with the Generic Fanuc post and see how it works out?
https://cam.autodesk.com/hsmposts
Please click "Accept Solution" if what I wrote solved your issue!
tormode
in reply to: programming2C78B
Thank you very much for the redirect. I will give you an update when I have had it tested!
CNC_Lee
@tormode
If the generic Fanuc posts are not providing the required output for your machine, I offer post processor development services and happy to work out a solution for your machine! Message me if I can be of assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Fusion 360 CAM Post Processor Expert
https://linktr.ee/cnclee
serge.quiblier
Hello @tormode
As this is a Robodrill machine model, you can also try the robodrill post, available on the library,
https://cam.autodesk.com/posts/download.php?name=robodrill&type=post
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
tormode
in reply to: serge.quiblier
Hi Serge
Thank you for the feedback.
Our operator tells me this has been tested, and that there is something with the starting/0-point settings for the machine that do not seem right.
serge.quiblier
Hi @tormode
can you explain what it means : "0-point settings for the machine that do not seem right."?
Do you have an error?
Is it using a wrong wcs?
The wcs is selected inside the setup, a field contains a value that is mapping in the following way
1 : G54
2 : G55
Are you machining in 3, 4, 5 axis?
Regards.
Serge.Q
cam.autodesk.com
