Fusion Manufacture
post process mod - invert X direction on live tooling/radial
1 REPLY 1
programming2C78B
61 Views, 1 Reply
setting up our CL1 lathe and it requires the X commands to be negative since its on the "far" side of the part. How can I get these inverted in the post? No changes or flips in the Job Setup are reflecting in the produced code.
I need X-2.5, X-1.2, etc
Please click "Accept Solution" if what I wrote solved your issue!
1 REPLY 1
I use this function in my Okuma post for turning in the negative X direction:
/** Invert X axis for turning negative. */
function invertAxes(activate) {
  if (activate) {
	xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-2}); // diameter mode
	xOutput = createVariable({prefix:"X"}, xFormat);
    iFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-1});
    iOutput = createReferenceVariable({prefix:"I"}, iFormat);
  } else {
    xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:2}); // diameter mode
    iFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:1});
invertAxes(true) to activate, invertAxes(false) to deactivate.
