Fusion Manufacture
Post Process for UMC - Mirrored tool paths outputs a C180 (sometime after 43598 post)
4 REPLIES 4
dallasjcutler
186 Views, 4 Replies
I've been having to use old posts on any mirrored tool paths because the output C180 that spins the part 180deg along with the mirrored tool paths. I use the mirrored tool path for all parts that I have left/right and this definitely doesn't work.
Nothing I can do to fix it, I found a work around. But would be nice if it could get corrected in future releases.
Here's the latest post 44066
I found an older post that works, 43598 for NGC that works.
4 REPLIES 4
Are you also changing cutter direction when you mirror? I've wondered about a better workflow for Climb vs Conventional when mirroring
Yeah, exactly. Its cumbersome to do for every part I make to have to do but I haven't found a better option either.
in reply to: dallasjcutler
Are you able to share the f3d file?
dallasjcutler
Couldnt get a F3D even with linked components broken. But heres the F3z.
