Fusion Manufacture
Post process for machine ROMI D600 machining center FANUC - "Duplicate NC. Macro Instruction" ERROR
2 REPLIES 2
metalnorte.ba
72 Views, 2 Replies
I have a machining center from ROMI model D600 that works with Fanuc system. I tried to used Fanuc post process but it doesn't work. It says "Duplicate NC. Macro Instruction". Does anyone knows how to fix it? I need help with it.
2 REPLIES 2
seth.madore
in reply to: metalnorte.ba
Does this error show up when you post code from Fusion, or does it happen at the machine?
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
metalnorte.ba
in reply to: seth.madore
@seth.madore
Sorry for the late replay and thank you for your time.
I found the error. Post process  was putting T1 and M6 at the same line and the machine doesn´t recognize it. So I went to the post process and edited it. Now it is working good.
The machine manufactor helped me find the solution.
All the best
Angelo
