Announcements
Post process Error
bamberharrison
Community Visitor
Post process Error
bamberharrison
Community Visitor
Community Visitor
Hi, I have been trying to post a G code for my plasma cutter but every time i try to do so the same error keeps occurring and I'm not sure what it is i have also attached a picture
a.laasW8M6T
Hi
What version of the  Openbuilds Post are you using?
There was a bug that came in around 9 months ago due to some changes in the Fusion Post Kernel.
I suggest getting the latest version of the post here:
https://github.com/OpenBuilds/OpenBuilds-Fusion360-Postprocessor
bamberharrison
Community Visitor
Community Visitor
Hi, thankyou for replying i have updated it but i am still getting the same
thing
a.laasW8M6T
I was able to post process a simple plasma cutting test file.
There must be some aspect of your setting that is causing the error.
Can you share the Fusion File that is causing the problem?
Goto File>Export>Save as .f3d/.f3z and attach to a reply here.
Can you also attach a screen shot of what the post settings you have are?
