Fusion Manufacture
POST Help : 3-axis Mill/Turn Carver (XZC)
1 REPLY 1
chibbardY9XV5
155 Views, 1 Reply
I have a custom-build foam carving machine that requires post.
The spindle move along the X and Z axes
The stock is mounted along the X axis and rotates about this axis (call it, A)
The X,Z and A axis interpolate
There is no coolant or tool changer on this machine. Just a spindle + 3 motors (with limit switches)
Setup uses the MachMotion 2000 Series Controller. From this, I believe Mach3Mill and Mach4Mill posts are accepted, others may also be accepted that I am unaware of.
In Fusion 360 we use the Rotary toolpath included in the Machining Extension
As is, the rotary toolpath creates code along the X, Y, Z, and 'A' axes. I am looking for a way to lock the Y axis from moving.
I am aware of the "XZC mill-turn programming in Fusion 360 CAM" Autodesk Support article. But the POSTs i have explored do not contain options corresponding with this solution.
Can this be solved within Mach3Mill or Mach4Mill Post? Or do I need a different post-processor
EDIT: I believe a modification must be made to prevent movement of the Y axis in the Mach3Mill post. I will continue to attempt this restriction,  but I am not experienced with postprocessing
1 REPLY 1
Hello @chibbardY9XV5
Are you using the latest mach3mill post, with or without a machine simulation file?
Or did you enable the fourth axis support via the post property?
Because the kinematic definition, and the parameters defining the axis will have an influence on the code generated.
Particularly, the tcp setting.
Can you share your data's? (post, eventual machine file, f3d)
You can either share a link to your Fusion file. See:
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
or you can save an archive (f3d, or f3z) and share it on the forum
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
