Post for Okuma LB3000EXii-MYW
nickGX2SM
nickGX2SM
There are a couple threads I've seen that reference this machine and the authors search for a suitable post for Fusion 360 CAM, but nothing that I can find that results in an actual file / attachment available.
We are wanting to integrate Fusion CAM workflow with this machine which includes mill/turn & Y axis.
Does a post exist or will we have to look at creating one?
Thanks for any info / help in advance.
Nick
Laurens-3DTechDraw
Some re-sellers might have something close for that machine.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
nickGX2SM
Hi Laurens,
Do you mean local Fusion360 resellers? Or HSMWorks resellers?
Nick
Laurens-3DTechDraw
Any Autodesk CAM re-seller.
But since this is a little more tricky the (old)HSMWorks re-sellers might have a little more experience.
Laurens Wijnschenk
3DTechDraw
jeff.walters
We have brought the Autodesk CAM forum (mainly HSMWorks and Inventor HSM users) over. It’s called INVENTOR HSM & HSMWORKS CAM. In that area there is a post section and if you ask over there you might find someone with a post or who can help you get one written. Since they all use the same post processors a post from any of the systems will work in Fusion.
http://forums.autodesk.com/t5/post-processors/bd-p/218
Jeff Walters
Senior Support Engineer, CAM
