Fusion Manufacture
post edit
2 REPLIES 2
Karl.lund
110 Views, 2 Replies
post edit
hi all
i have been playing whit Haas ST-20 post, what is the simplest way to change g0 and g1 to g100 and g101 for c-axis?
 my controller uses g0 and g1 in turning but in c-axis milling and drilling its uses g100 and 101
thanks, Karl
Karl
2 REPLIES 2
seth.madore
in reply to: Karl.lund
This is all for the main spindle? Looking in the post, it appears that G100 is listed for Primary spindle and 101 is defined for Secondary spindle, and these are Mirror Image codes
https://www.haascnc.com/service/codes-settings.type=gcode.machine=lathe.value=G100.html
Seth Madore
Karl.lund
in reply to: seth.madore
hi
aim trying to make st20 post work for my controller heidenhain datapilot 31xx, in turning it uses g0 and g1 but when c axis is enabled it uses g100 and g101 for c axis movement. but post post g0 and g1 c axis movement, is there a way to fix this.
or is maybe another post whit is better for this controller
its only 1 spindle machine gildimaster gtx400
thanks Karl
Karl
