Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Pocket Contour Warning: No Pass to Link
2 REPLIES 2
dcolley_ptfnola
236 Views, 2 Replies
This seems to be an issue I run into a lot.  I've created a pocket and want to create a 2D Pocket contour.  The pocket is 1/4" wide and 3/8" deep.  I've selected a 1/8" x 3/4" (flute length) flat end mill.  Still, I get the dreaded "No Pass to Link" error.
I'd think a 1/8" dia. bit should cut this fine.  Thoughts?
David Colley
Picardie Timber Frame + Millwork
New Orleans, LA
Tags (1)
Labels (1)
2 REPLIES 2
Ya, it should cut for sure, but hard to say what is preventing it from happening without the file.  Sometimes it's one little thing the blocks everything, can't say without seeing it unfortunately 😞
If I had to wager, I'd suspect that it's the Helix setting. Chances are that it's swinging a larger arc than what can fit in there.
But, like @DarthBane55 suggested, if you can share the file, that'd be best, as it gives us everything we need to know.
Seth Madore
Technology Administrators
