this may not go to the right board as this seems to not be behaving correct either. tool 35 center pocket, plunges too close to stock. no exit or entry will work. Used pre drill and cutter plunges into stock then ramps so that is not an option either. with no pre dill, at the end of the path the tool lifts while engaged with stock. it may look right on the simulation but the code is wrong,
