Announcements
plunge at ceneter
magpiemachining
plunge at ceneter
magpiemachining
Tool needs to plunge in the center. sketched a point in the center still doesnt plunge there and it needs to go back before it retracts. Any help on this? i never get the entry point to work as easy as it sounds it should be.
seth.madore
In this case here, using 2D Contour, your only option would be to extend the lead-in/out until it's something you are satisfied with.
-EDIT- In this case, anything around .2396" should get you a lead from and to the center point of the part
Seth Madore
