PLEASE HELP
vladimirtrubin
PLEASE HELP
vladimirtrubin
Hello. I was wondering if one the gurus would be able to analyze this and teach a thing or two please.
So i have been trying to figure out how to pocket out this model. For some odd ( to me ) reason when selecting a contour ( chain ) to pocket out it does this completely odd path. almost like this is not a solid body.  i tried many ways. open and closed
ovisopa
I'm no guru, but I opened you file and I'm not sure if that is the area you are trying to pocket, is that it ?
I noticed that both 2D adaptive and 2D pocket are failing in creating a good toolpath (it mills through the model) but the 2D Contour operation seems to make an usable toolpath, if you need to mill quick a part, and can't wait for an answer from the guru's around here, maybe you can make a pocket with a STOCK TO LEAVE value to avoid milling through the material, and than make an 2D CONTOUR operation to finish the internal edge
Good luck!
vladimirtrubin
Thank for your suggestions, interestingly enough this model has two of this parts. Second one is not a mirror. It was also extruded from sketch that was copied and paste into a new sketch. That second part pockets the path perfectly.
:confused_face:
