Fusion Manufacture
PLEASE HELP ME I MISSED WHEN USING THE PLEASE HELP ME WHEN I USE THE CIRCULAR POCKET MILLING
4 REPLIES 4
thien117
119 Views, 4 Replies
4 REPLIES 4
seth.madore
in reply to: thien117
This is a bug that was accidentally released in the last update. We've logged CAM-42648
As a workaround, I suggest using the actual Bore/Circular toolpath
Seth Madore
thien117
I got the knife setting error when drilling
thien117
in reply to: seth.madore
when will the update fix the bug .we are using the above toolpath which is very suitable for our work
seth.madore
"knife setting error"? I'm not sure what you mean by that..
As for when the bug will be fixed; it's unknown at this point, but I don't suspect it's going to be relatively soon. The only solution is to use an alternate (more proper) toolpath for your Bore/Circular needs.
Or, hand edit your feedrates to not be zero (yuck)
Seth Madore
