Plasma Feed Rate Issue
I am using the waterjet/laser/plasma preview option. Has something changed recently that is causing waterjet/laser/plasma contours to not post process with proper feed rates? All jobs that I try to post to gcode now have a feed rate of 0. All feed rates in the file are F0. I have tried this with my custom post processor for linuxcnc and with the factory supplied post processor Hypertherm-Jet. Both post out F0 for feed rates when the contour has a feedrate defined as 40in/min.
LibertyMachine
This is a known bug and will be addressed in the December Fusion update
Source: https://forums.autodesk.com/t5/computer-aided-machining-cam/post-processor-feed-rate-problem/td-p/67...
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Thanks Seth,
I though it must have been a bug but I did not find anything when I did a quick search.
Thanks again.
Jim
