Peck drilling with UMC 750
jonas.wassdahlYCD2Y
jonas.wassdahlYCD2Y
I have difficulties with performing peck drill with my HAAS UMC 750 with pecking depth reduction. It seems like the UMC 750 post processor does not take into account the pecking depth reduction parameter.
Anyone that have solved this issue with the post processor?
BR
Jonas W
raymus.houston
I actually just had this same issue about a week ago. The code to handle pecking depth reduction is absent in the UMC-750 postprocessor. I changed it using the code from the Haas VMC postprocessor which does have it.
You will want to change the deep drilling case to the following red colored code. It should be under the onCyclePoint() function in the UMC-750.cps:
case "deep-drilling":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
        getCommonCycle(x, y, z, cycle.retract, cycle.clearance),
        // UMC-750 ORIGINALS
        // "Q" + xyzFormat.format(cycle.incrementalDepth),
        // "P" + milliFormat.format(P), // not optional
        (((cycle.incrementalDepthReduction > 0) ? "I" : "Q") + xyzFormat.format(cycle.incrementalDepth)),
        conditional(cycle.incrementalDepthReduction > 0, "J" + xyzFormat.format(cycle.incrementalDepthReduction)),
        conditional(cycle.incrementalDepthReduction > 0, "K" + xyzFormat.format(cycle.minimumIncrementalDepth)),
        conditional(P > 0, "P" + milliFormat.format(P)), // optional
        feedOutput.format(F)
      break;
jonas.wassdahlYCD2Y
Great, big thanks!
BR
Jonas W
