Patterning issue after update
I am running parts that I have patterned around a rotary. What I used to do when doing a setup was to select the operations themselves one by one and post them, which would let me just cut 1 part in the original pocket, once a part was dialed in and tweaked, I would then post the whole program and it would post all the parts around the rotary. Now no matter what I do I cannot just post the original part, no matter what I do it post for all the parts. I do not want to have to delete all the patterning out to just post a single part. Any idea what changed or how I can just post the original?
seth.madore
Unfortunately, this was a side effect of implementing In-Process Stock generation. At the moment, there's only one workaround; move the toolpath out of the Pattern, or modify the Pattern instances until you are ready to pattern the full amount.
They are exploring solutions for this, and that would likely involve the NC Programs dialog in some fashion.
Sincerely apologize for this inconvenience 😞
Seth Madore
Thanks for the response, Ill find a workaround for now
