Thank you for all your good ideas.
I have posted this in the Japanese forum, but I would like to enhance the ability to adjust the toolpath feed speed.
Currently, I think you use a threshold to detect the angle of the line between adjacent points and apply an appropriate feed rate.
However, in the case of 3D fine point cloud toolpaths, it is very difficult to control the detection with a threshold angle because there is almost no angle difference between adjacent lines.
Fusion has added some nice features such as toolpath editing and toolpath deletion, but I would like to see this functionality applied to allow the user to set an additional feedrate for an arbitrary range of toolpaths specified by the user.
For example, when performing finishing operations such as 3D mold machining, there are cases where the feed rate of near-perpendicular corners and small radius irregularities may need to be partially adjusted if the finishing tolerance is set strictly.
Please consider this.
Japanese Forum:
微細点群のツールパスでも送り速度を変更できる機能 - Autodesk Community
