Part Off Operation
bflug
Part Off Operation
bflug
I am wondering about certain features of the part off operation.
After it had cut through the part is there any way to rapid out or use lead out federate instead of a cutting federate to get back to clearance?
Also the order of operations could be improved and I'm at a loss of how to do it in the post, I feel it may be a bigger fix.
When parting there is no need to have the part catcher out when removing 90% of the material as it just fills with chips, which are an issue when running unattended. Also when we reduce the federate is is essential to also be able to reduce the spindle speed, otherwise you can easily throw you parts around and damage them or miss the part catcher.
What I'm proposing would be that when you reduce the federate you can also reduce the spindle speed, and that is when the part catcher will come out. Then when past center and leaving the part I can use lead out federate.  If this can be achieved strictly with changing the post that would be fine but if this needs to be implemented through the idea-station let me know.
jeff.walters
I am assuming you are referring to turning cut-off. Right now there isn’t. It has already been reported on ticket CAM-3486
Jeff Walters
Senior Support Engineer, CAM
