Fusion Manufacture
Parallel toolpath trouble (no passes to link)
4 REPLIES 4
Vintagetunes
113 Views, 4 Replies
Hi there!
 I'm working on a big wall project in high density polyurethane, and I'm having trouble setting up a parallel finishing pass for multiple parts.  I've tried setting up all three parts in the same toolpath, but it ignores all but the first part.  When I duplicate the toolpath and try to set them up individually, I get a "no passes to link" error.
I'm sure that I'm probably  overlooking something pretty basic, but I really can't find the issue.
Any help would be hugely appreciated!
(Bonus points if you have feeds and speeds recommendations for 15lb corafoam lol)
4 REPLIES 4
seth.madore
in reply to: Vintagetunes
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Seth Madore
Vintagetunes
in reply to: seth.madore
Oops. Here it is!
seth.madore
The issue is that you only have one model selected in your Setup:
Also, I'd just use "Touch Faces" to contain the toolpath:
Seth Madore
Vintagetunes
Awesome! That did the trick! Thanks so much!
