Fusion Manufacture
Parallel mode starts at Origin.
3 REPLIES 3
ian1196
269 Views, 3 Replies
I am using Parallel mode to remove some draft. I have defined the area but Parallel starts at the Origin. See Parallel3. How do I avoid this?
3 REPLIES 3
seth.madore
in reply to: ian1196
Okay...that's not supposed to be happening. This deserves closer examination.
To workaround this, you can select "Touch/Avoid" faces to help constrain the toolpath:
Result:
I've opened up CAM-41895 to investigate this issue 
Seth Madore
ian1196
Thank you Seth. That is my work-around. However, I still have to "chase the cut" using Avoid
seth.madore
This issue has been fixed in the update that went out last night, sorry for the inconvenience!
Seth Madore
