Fusion Manufacture
Parallel Finishing: can't control direction and entry point
4 REPLIES 4
rumpelstielz
1887 Views, 4 Replies
weird issue: i need to parallel finish this 10° slope and want the toolpath to start at the highest point and move down the slope. I can't find a way to do this, Fusion will always start the toolpath at the low point:
even if i set the entry point to be at the top corner it will start on the bottom, pass options for one way, other way or both ways also always have no effect on this and result in the same start point.
How do i control this ?
Heres the file: https://a360.co/2JjDRsb
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
4 REPLIES 4
Use the pass angle, if it's zero set it to 180°. Just increase what you have by 180° to change the end it starts at.
Mark
PS you'll get more help if you export the file and attach, those download links are a time waster.
Mark Hughes
Owner, Hughes Tooling
@HughesToolingha .. whaddayaknow .. would have never thought of that 🙂
Five years later and I have the exact same question.  The "pass angle" solution seems elegant but I can't find that option in my current version.  Perhaps something has changed.
Manufacture:3D Parallel:Passes Tab: Pass Direction=0 deg  seems to have no effect when changed to 180 deg or any other increment.  Pass Direction Reference also seems to have no effect.
I'm a rookie but any help is appreciated...just finding this thread has given me some reassurance that I'm not totally alone.
halftonJW8QY
in reply to: halftonJW8QY
Never mind.  Changing "Pass Direction=180 deg" worked.
Thank you very much.
