Parallel crash :(
Parallel crash :(
Hi, I just crashed my machine because i get something like this:
But when I click CTRL + 7 I can see this...
What is that? Why it goes so deep? There was a middle plane higher than this.
Replies (7)
LibertyMachine
Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
If you can't share the file, I'd be happy to take a look at it privately
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
file is in the attachment
Boopathi_Sivakumar
@Anonymous
Just Disable the contact only in the geometry tab it will sort out your problem
126.JPGThanks,
Boopathi
Boopathi Sivakumar
Sr Application Engineer
www.usamcadsoft.in
Facebook | Twitter | LinkedIn
Thanks a lot, but I think it is not the real solution for this issue. I also found a solution like this, I mean this operation was made by "create derived operation". If I make this operation from scratch it will work fine.
But I hope someone from Autodesk should check what is the problem, because someone can have a really bad accident on a milling machine. Fortunately I was near the machine and stopped it immediately. I broke only an end mill.
GeorgeRoberts
Thank you for sharing the file. We are looking into this issue and will update you as soon as we find a solution.
It looks as though it could be related to the smoothing option (disabling smoothing rectifies the issue)
Apologies for any inconvenience
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
LibertyMachine
In addition, leaving Smoothing on and opening up the Tolerance to .015mm also rectifies the issue
Seth Madore
Thank you all! I hope the problem will be solved!
