Fusion Manufacture
(OSAI CONTROLLER)Need a Post processor for Laguna smart shop 3 OSAI CONTROLLER
7 REPLIES 7
Message 1 of 8
zbolich
283 Views, 7 Replies
Could someone please tell me if there is a Post processor for a laguna ss3 with and OSAI  (NOT FANUC) controller. Or t\is there a way to have one made?
thank you
7 REPLIES 7
Message 2 of 8
engineguy
in reply to: zbolich
@zbolich
There are two Post Processors currently available for the OSIA CNC control, one is a Generic Mill and the other is for a CANCAM Router, both are attached below and are the latest versions having been updated only 2 days ago 🙂
Hopefully one of them will work OK for you, if  one is close then it can probably be Edited to suit your machine control.
To get it exact you would need to supply some example code either from the machine or the Operators Manual 🙂
Message 3 of 8
zbolich
in reply to: engineguy
I have attached 3 files. I really appreciate your help thanks
Message 4 of 8
zbolich
Here is the code from the manuals as well
Message 5 of 8
engineguy
@zbolich
OK, now you need to do an example program and Post the code with each of the Post Processors that I uploaded for you, then you will be able to see which one works the best on your machine, then you will be able to say if it needs any modification 🙂
I got your .PDF file but no other files were uploaded, if you want to upload a Fusion file then go t:-
File > Export > Select f3d format > Save to a location on your computer > then attach to your reply.
Message 6 of 8
tupelored
do the post work with the dill black? My Smartshop III have the dill block.
Message 7 of 8
zbolich
in reply to: tupelored
You are the first person to contact me about this. I dont know if it works
with the boring block. I also have a boring block, but I don't know what I
am looking for to see if the post-processor matches Fusion's generic
post-processors. Are you able to use fusion with your post processor? I
cant even get the to work
Message 8 of 8
tupelored
We gust got it and it is no even hooked up yet. I was looking for a post processor for Fusion or Bob Cad.
