Hi, i try cam some like this https://gyazo.com/10329a7c702abbc819ceed8b5be01e68 this is mould form for my hobby
i mill use "3d parellel" but i need before made draft cut and i have some like this https://gyazo.com/c29ee91061b99bdc61b73e864a315509
How i can optimeze tool path by z axis
Sergey
update: https://gyazo.com/979dd8d5305b0fe8bd861c4cbb2ef7f8
Solved by HughesTooling. Go to Solution.
Can you go to the File Menu and Export the part as an f3d file and attach to this thread please.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Sorry for not getting back on this quicker. I have a couple of ideas using pocket, the problem is the stock is wider than the part so to get a similar raster cut to what you were trying you need to machine the stock down to the outside of the part. The other option is just to pocket the part.
Here's the part machining the outside first.
And here with a pocket.
I've attached the file with both versions.
Mark
Mark Hughes
