Optimal load must be less than groove radius - but it is
- Mute
- Permalink
- Report
I am turning a 19mm groove into a part using the adaptive turning operation. i have used this hundreds of times with no issue. since the last update i am encountered with two problems.
firstly i can no longer use a grooving tool with this operation as i get the error tool is not suitable for this kind of tool path you likely need to change your tool ( i have been using the exact tool i am trying to use on the same file for over a year now)
secondly i tried to define my tool as a button tool which it tecnically is but i have always got by defining it as a grooving tool and once doing this i get the error optimal load must be less than groove radius but my optimal load is set to 0.5mm and the radius of the groove is 19mm.
this is stopping me making lots of parts which is very frustratying as i cannot see where i am going wrong and i have been doing this the same way for nearly two years. i have opened files i have previously worked on and tried to regenerate them but i am getting the same problem once the toolpath is regenerated even though it was a complete and correct toolpath before generation.
Fusion
