I have to mill several open pockets and I'd like to use a 2D Adaptive toolpath. However, I'm getting warnings about a "rapid collision with stock" that I don't know how to address.
I thought that in the 2D Adaptive toolpath the bit spiraled in to the stock. In this case, it plunges in to the full depth before tracing a path. This puts too much of a strain on the bit, and thus is something I'd like to avoid, but I don't know if it is possible. Does the 2D Adaptive toolpath only spiral in for closed pockets, not open ones? Can I ramp in somehow?
I could use multiple depths, of course, but that seems to defeat the purpose of the Adaptive path.
Solved by engineguy. Go to Solution.
@engineguy is right you probably want to use 3D adaptive.
The reason why you are getting a plunge into stock is because your stock contour selection is wrong. You have selected that pocket as the stock so the toolpath thinks it is plunging outside of the stock material hence there is no helix.
