In the attached file why does Pocket1 have 2 levels I've set the step down to 10mm so you should get one level only. In the other Pockets I've set the Top Height to -1 to get one pass.
Mark
Mark Hughes
Owner, Hughes Tooling
Solved by jeff.walters. Go to Solution.
It kind of looks like you have selected more chains/contours than desired (ie. both top and floor of pockets). At least this is my guess from the toolpath you have. Try to clear your contour selections and make sure to only select the floor for each pocket.
Keep in mind that by default the Bottom is set to "From Contours". So you get cuts for each Z level that you select. If you then edit the Bottom height to a fixed value, all the different Z levels get projected to that specific Z level.
I only had the top contours selected, selecting the bottom of the pocket makes no difference. I have the Top Height set to Stock top and Bottom Height as a selection, one of the pocket bottom faces. I've tried entering absolute dimensions, selecting different faces etc. but I still get 2 levels! The levels of the tool paths are -0.5 and -9.5 so for some reason it's only allowing a 9.0mm step.
Thanks Mark
Mark Hughes
@fonsecr wrote:Keep in mind that by default the Bottom is set to "From Contours". So you get cuts for each Z level that you select. If you then edit the Bottom height to a fixed value, all the different Z levels get projected to that specific Z level.
I tink that's for 2d pockets, these are 3d and I've selected the bottom face.
thanks Mark.
Mark Hughes
Ok. Can you send a mail to cam.support@autodesk.com? Then the support team can do an online session with you to go through that settings and see if there is anything that would cause this.
If you use 3D Pocket, then default Heights should be fine. It will use the stock height that you have set in your Setup.
Thanks Jeff, I guess Flat area detection is on by default I'll turn it off so it doesn't catch me out again. It seems odd that it's working the way it does though, I've used a few other CAM programs with flat area detection and they seem to ignore the top face of the part. I suppose the work around is to set the Top Height below the top face of the part.
You are right 2d pocketing would be a better option, the file was to demonstrate another problem.
http://forums.autodesk.com/t5/computer-aided-machining-cam/warning-when-pocketing/td-p/5467997
As you have the file any thoughts on that problem.
Thanks Mark.
Mark Hughes
