Fusion Manufacture
On the same process the machine time is different
1 REPLY 1
Laurynas_Infoera
153 Views, 1 Reply
How to know which machining time is correct? On the same model it show different times, but I haven't change anything, but in four windows it shows different time.
The simulation statistics show (0:02:08)
The machining time show (0:02:04)
The setup sheet show (0:03:50)
The setup sheet show (0:01:33)
I need +- accurate time for calculations.
So how do I know witch time is correct.
Labels (1)
1 REPLY 1
I find the Machining Time to be the most accurate, in that it offers the ability to scale the actual result. For example, I've set my Mori to be at a factor of 81% and the Machining Time and actual on-machine time are within a minute of each other (on 1 hour cycle times).
Truthfully, this isn't something we've invested a great deal of time in, as there are many external factors that play into this value.
Seth Madore
