Fusion Manufacture
Omit a single hole from drill selection?
5 REPLIES 5
programming2C78B
154 Views, 5 Replies
This part has triple digit # of holes in it, and there is ONE that needs to be omitted as the tool will collide into the "island".
For now, I've just thrown in a patch and called it a part of the model BUT it now invalidates the REST machining/stock that I have from the previous ops. I could export-import a mesh of op 1, but is there an official and proper way to do this?
Only other idea is a make a sketch that goes around this one hole, then do a containment on the drill cycle.
Please click "Accept Solution" if what I wrote solved your issue!
5 REPLIES 5
No, containment boundary is your main option. But it would be nice to be able to Shift+Click a hole to omit it...
Seth Madore
Yes, like Seth said, containment boundary works, I just did it.  Select the part contour, then ALSO select the hole to skip, it will skip that 1 hole.
Like this:
Seth Madore
yep got it. Kinda the same as Stock selections where it then considers the inside profile as a void.
Tomas_V_cz
in reply to: seth.madore
great trick, I didn't know that
