Fusion Manufacture
okuma post processor posting wrong coordinates
3 REPLIES 3
stewartPHLNF
212 Views, 3 Replies
There is a discrepancy between the simulation coordinates and the output from the Okuma post, specifically in the Y direction. When I run the program on the machine, it attempts to drill in the wrong location. The Y coordinate from the simulation appears to be correct for the drilling location. The difference between the two Y coordinates seems to be consistent with where the drill should actually be positioned. I'm using the machine configuration that was already in fusion for this machine.
3 REPLIES 3
TrollTuner2
in reply to: stewartPHLNF
Try Using Fixture Offset Function  (Call O088)  for the 3+2 stuff.      Its under the multi-axis tab in the post properties.   Thats what I use on my 460-5ax
(Slot Rough)
M09
M01
N4 T338 M06
S15000 M03
G17 G90 G94
G15 H03
G00 A-90. C145.488
M08
G131 F150 J1. E0.0004
CALL OO88 PX=0. PY=0. PZ=0. PC=145.488 PA=-90. PH=3. PP=51.
G15 H51
G00 X3.9127 Y-3.3008
CALL OO88 PX=0. PY=0. PZ=0. PC=0. PA=0. PH=3. PP=51.
G15 H51
   It uses H51 offset as a scratchpad.   offset H3 drives it in my setup.
stewartPHLNF
in reply to: TrollTuner2
That worked! Thanks!
TrollTuner2
Great.   Yell if you need anything.
Don't know much, but I get the Okuma to make the parts right most of the time.
