Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Not being able to export g code on cloud based Fusion
4 REPLIES 4
aidenyakuben1234567890
379 Views, 4 Replies
I have a part in cloud based fusion 360 that I would like to export the g code for. When I try to export the g code or post process, it pulls up the file explorer from the computer that Fusion is running on, not mine. I have not been able to find a solution for this problem online. Thank you.
4 REPLIES 4
Do you mean like a remote desktop connection to the computer running Fusion?
You need to setup a network share folder of some kind I would imagine, this seems like less of a Fusion problem and more of a network / local workflow issue
You have to post to a cloud folder and download from there.
Mark Hughes
Owner, Hughes Tooling
Just a bit more info. The browser version is running on a virtual PC so has no access to your drives and you have no direct access to its. You'll find some features have the option to open\save to your hub because of this (makes it less efficient for the rest of us😞).
Some more info here but doesn't seem to cover postprocessing.
Mark Hughes
Worked like a charm! Thank you.
