No valid toolpath
kamal_fouad
No valid toolpath
kamal_fouad
Teng Un problema una pieza de final de curso para programación pero no me deja he intentado todo hago todo bien siempre salta error toolpath
Matthew-R
@kamal_fouad
Gracias por publicar su pregunta en el foro de Fusion 360. ¿Podría compartir su archivo de diseño o adjuntarlo a esta publicación para que podamos ayudarlo mejor? Gracias.
Original Message in English:
Thanks for posting your question to the Fusion 360 forum. Would you be able to share your design file or attach it to this post so that we can better assist you? Thank you.
kamal_fouad
How can I do this part is for router CNC foam material I don’t know which pocket or adaptive use and how to solution toolpath error
kamal_fouad
this is my part
Matthew-R
@kamal_fouad Thanks for attaching your model. The first thing that I notice is that this part is 8ft. long by 1ft. tall. Is this scale correct?
If it is, this is going to take quite a while for any Adaptive Clearing toolpaths to generate and to machine the part itself.
Attached is the file that I modified. Important things to note:
1. Get your setup right, Z up, X,Y in the appropriate direction
2. Roughing Operation (Adaptive Clearing) to remove the majority of material
3. Finishing Operation (3D Parallel)
This is just a minimal setup to get you going and I'm sure you'd need some more operations to really machine this cleanly. Also, you'd need another setup to machine the opposite side of the part if you need to.
I hope this is helpful and let me know if you have any other questions!
kamal_fouad
Thanks for this solution
As you see the router is 5 axis
I can do in two parts
The under one will use drill tool?
