Fusion Manufacture
No Threads to machine
6 REPLIES 6
ChevelleNV
120 Views, 6 Replies
Every cam operation on every part I have with threading is now giving me the "No Threads to Machine" and these are all pre-existing jobs I have used before. I am unable to post any threading operations. any clue why this now no longer works when they worked previously?
I have tried deleting the operations and re-creating them with the same error, I have tried changing 'Spun Profile" I have even re-created the part from scratch. I have tried with Modeled threads and without. I am pulling my hair out and need to get this job up and running today HELP
They are all lathe parts and using a HAAS post which has NOT changed
6 REPLIES 6
seth.madore
in reply to: ChevelleNV
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
ChevelleNV
in reply to: seth.madore
Here's one of the files with the "No Threads to Machine Error" I have about 6 more if needed
seth.madore
I found the issue.
These features are not concentric, there was a modeling issue:
If we set our Rotary axis to the undercut, we get a toolpath:
Seth Madore
ChevelleNV
so why did it work previously?
ChevelleNV
and second, how do I fix this, its a turned profile.
seth.madore
You fix it by fixing the model or changing which surface you've designated as defining your Z axis.
Why did it work before? Well, it really shouldn't have, since you're working with eccentric features. I suspect we've done stuff in the "Spun Profile" to generate the results you're seeing.
Seth Madore
