Fusion Manufacture
no machine simulation or the ability to post a nc program
8 REPLIES 8
Message 1 of 9
michael_forresterWZX5P
204 Views, 8 Replies
since the update has anyone had issues running machine simulation or generating programs?
8 REPLIES 8
Message 2 of 9
No, I don't think I've seen any issues (in general). Can you share some more info as to what you're running into, perhaps a file/video that demonstrates this issue?
Seth Madore
Message 3 of 9
When i go to generate a nc file on  fusion it just goes back to machining screen . Highlights all the cycles blue. And that is it. I have to close down fusion to be able to edit cycles.  The exact same when i do a machine simulation. normal simualtion is fine. I have only noticed this since the last update. There would be nothing to show with a video sorry.
Message 4 of 9
I assume this is in Production Fusion, not Insider?
Mac or PC? What OS?
What are you using for a machine configuration? Does it work if you either A) don't select a machine config, or B) select a different generic machine config?
Is this 3, 4 or 5 axis work?
Seth Madore
Message 5 of 9
This is Autodesk fusion manufacture . Using windows . This is 3-axis work . I have used this exact file and post with same machine before the update and outputted programs and ran the machine sim. I have tried using different machines and different machining files on numerous setups within our business and all are behaving the same way .
Message 6 of 9
Can you share that Fusion file and machine configuration? To share:
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply  (.f3z is generated if the file contains XREF documents or Machine Configs)
Seth Madore
Message 7 of 9
i have a remote call at 10am i will upload file if this doesn't get resolved. Thanks for your help for now
Message 8 of 9
Message 9 of 9
Unless it's something native to your environment, it's not going to be anything we can resolve without the file. Upload it when you can 🙂
Seth Madore
