Fusion Manufacture
No luck generating a toolpath
2 REPLIES 2
andrea_swift
138 Views, 2 Replies
Hello!
I'm attempting to cut out a business card sized model from 4mm plywood with a small end mill (either .8mm or 1mm), but I'm super duper new, and can't seem to select the right combination of options to get it to generate a toolpath to cut out the models.  I'm sure I'm doing something stupid.  Apologies.
The cnc is a sainsmart 3018 prover, and the model is attached.
I would love to have tabs between the parts so it all stays together until the end user snaps it apart, but can't figure that one out either.
Thank you in advance!
Labels (1)
2 REPLIES 2
seth.madore
in reply to: andrea_swift
The two end slots are .75mm apart, were you planning on a different tool for those features?
Seth Madore
andrea_swift
in reply to: seth.madore
Son of a nutcracker, yea, that was it.  I thought I had made all the toolpaths > 1mm, but I musta screwed something up.  Once I fixed that, it was able to generate the 2d contour and tabs just fine.
Thank you!
