Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
No entry point selection for 2D Circular, why?
5 REPLIES 5
feklee
438 Views, 5 Replies
With 2D Contour, it is possible to specify an entry point.
With 2D Circular that is not possible. I could use 2D Contour instead, but still I wonder: What is the rationale?
Tags (3)
5 REPLIES 5
LibertyMachine
in reply to: feklee
It's anybodies guess as to why, and I don't think you are going to get a developer to chime in and give the rationale. It would be nice if I could define an angular entry (such as entering at the 3 'o clock position), if I don't have the option of defining a point. I know I asked the question a long time ago and was given a non-answer, of sorts
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
in reply to: LibertyMachine
I agree, also it would be really neat if we could do an overlap as found in the chamfer operation, Just  to try to reduce the entrée step that sometimes forms in 2d circular
Steinwerks
in reply to: feklee
Honestly the Circular toolpath is just a stripped-down 2D Contour. I haven't used it in years, as it's just not adaptable or adjustable enough IMO.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
LibertyMachine
in reply to: Steinwerks
Agreed. The thing that I do like about the Circular operation is the "Lead to center" aspect, which is replicable (is that a word?)  with math on the 2D contour option. The reason I like it is I'm occasionally splicing together programs, or doing quick edits at the machine. Having the center option gives me a bit of confidence boost when I'm juggling a dozen other things
Seth Madore
Steinwerks
This is a nice feature, especially if you have a drilled hole already in the middle. My go-to for that though tends to be Bore which has the same function but I don't have to bother with stepdowns and a bunch of linking. However I can see how Circular might be very useful if one doesn't have a powered Z-axis and needs to set Z height manually with a quill (like a Proto Trak or EZ Trak conversion).
Neal Stein
Find me on:
