Fusion Manufacture
Newbie having trouble with 3d toolpath
4 REPLIES 4
jeepinbootz
117 Views, 4 Replies
I've been trying to wrap my mind around how to make these curved parts and i've run into a wall. I decided on making a fixture to hold the raw material at an angle so i can hopefully make these in as little as 2 operations. Shown in the picture is a fixture that will hold two parts at a time. My plan is to rough out the top and outer profile of the part, then do the pocket, drill holes followed by a semi finish and a finish. I cannot for the life of me make a tool path to go around the profile of that part while moving on z and removing all excess material down to the clamps. I attempted adaptive machining but its ignoring the angle of the part and cuts on a level plane right through the fixture.  This is my first time with 3d machining . Im going to be doing this on a haas  super mini mill 2
4 REPLIES 4
a.laasW8M6T
in reply to: jeepinbootz
If you could share you file here it would make offering suggestions much easier
Go to File>Export>Save as .f3d/.f3z
then attach to a reply here.
You will likely need 3D adaptive to rough out and several 3D toolpaths to finish
jeepinbootz
in reply to: a.laasW8M6T
i'll be honest i'm kind of embarrassed of my work, it might not be exactly the correct way but i'm learning as i go.
a.laasW8M6T
You have done a pretty decent Job for a beginner, The design timeline is a bit of a mess and has a few warnings, but i'm not going to look at that, i'll just focus on the cam stuff.
Have a look at this video, If you have any further questions feel free to ask.
jeepinbootz
I can't thank you enough for the time you put into helping with this issue. I've learned alot from this video and you make it look really easy. I got my homework to do this weekend and I follow along with your video and try it for myself. Thank you again and if all goes well I'll post a picture of the finished product!
