Fusion Manufacture
New mazak post, how to reverse rotary 4th axis?
8 REPLIES 8
Message 1 of 9
programming2LQMT9
275 Views, 8 Replies
Small issue here. I've got a part that'll need a continuous/live rotary motion, and I've only ever indexed on this machine before.
Seems the Mazak w/rotary post is obsolete, and it's what I was normally using. The new post gives no menu options for inversing the rotary on the table, and I can't seem to get it to spit out the right code. I've tried editing the post itself, and it still seems to be backwards. I generally don't use machine setup/sim and just select the post.
Machine's a 510c-II, Mazak Nexus control.
Below is the bit of code I've edited:
  if (false) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], range:[-360, 360], preference:1, tcp:useTCP});
8 REPLIES 8
Message 2 of 9
drd_808
in reply to: programming2LQMT9
open the post and search for 'reverse' or 'mirror' and find the corresponding code to change 'false' to 'true.' This is what the dialog boxes are actually doing when you check or uncheck something
If i remember correctly there is a g code to mirror an axis as well that would probably work
Message 3 of 9
programming2LQMT9
in reply to: drd_808
Nothing of the sort in the new post.
The older post is completely different.
Message 4 of 9
Change the coordinate from -1 to 1
 var aAxis = createAxis({coordinate:0table:trueaxis:[100], range:[-360360], preference:1tcp:useTCP});
you will probably have to change use TCP to false too as i dont think most Mazak 4 axis machines support TCP
its above the axes, change the var useTCP to false
function defineMachine() {
  var useTCP = false;
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120, 120], preference:1, tcp:useTCP});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:0, tcp:useTCP});
    machineConfiguration = new MachineConfiguration(aAxis, cAxis);
Message 5 of 9
Looks to have worked, except I'm not sure the machines will like G68.2 and euler outputs vs. calling the axis/angles. Any idea on that? Machine's currently setup for production, so I can't check for a few days.
output now looks like:
ROTARY POCKET1)
N25 T3 M6
N30 S1300 M3
N35 G90 G94 G17
N40 G54
N45 G0 I0. J-0.982542 K-0.186042
N50 M8
N55 G68.2 X0. Y0. Z0. I0. J100.722 K180.
N60 G53.1
N65 G0 X0.159 Y0.
N70 G69
N75 G43.5 H3
N80 G0 X-0.159 Y-1.8914 Z-0.3581 I0. J-0.982542 K-0.186042
N85 X-0.159 Y-1.4984 Z-0.2837 I0. J-0.982542 K-0.186042
N90 G1 X-0.159 Y-1.0739 Z-0.2033 I0. J-0.982542 K-0.186042 F13.333
Message 6 of 9
Hi
I have just checked on the standard Mazak post with the following changes:
  • set tcp off
  • change range to 0,360
  • make the axis cyclic
give nice axis only coordinates, with inverse time feed:
You should look into using a Machine definition rather than hard coding the axis info in the post, its much easier to get it to do what you want:
plus if you want you can create a machine for machine simulation
all the documentation is here:
https://help.autodesk.com/view/fusion360/ENU/?guid=MFG-REF-MACHINE-BUILDER-V2
anyhow heres the attached modified post
Message 7 of 9
I can't find a decent document to explain machine setup with the new builder, for setting up a reversed rotary. I do need to look into using machine sim/def at some point (the machines is already in the library) It just seems to have a unpolished setup and lacking documentation. We're a job shop, I don't really have the time.
The edited post looks like a good start, but it still wants to use i/j/k for non-live positional moves on the a axis, and still will only post as if the rotary is inline with x+
I still can't seem to figure out how to reverse the axis and keep the setup wcs where it should be.
Message 8 of 9
Hmm the latest Mazak post doesn't have the ability to turn off G68.2, which is pretty annoying.
I'll look into it later today
Message 9 of 9
in the post search for "useTiltedWorkplane" and set it to false, now it will position with axis angles rather than G68.2
