Fusion Manufacture
New Angled Entry for Turning Profile Rough w/ rest machining enabled
4 REPLIES 4
PROGRAMMING7K5CY
144 Views, 4 Replies
Wondering what happened to the old angle entry path for Profile Roughing operations in the turning workspace. I am sure the current version has its uses but for my specific case it causes an almost double in machining time per operation when I just need a slight lead in per cut.
This is the current path I have and would prefer that the angled entry does not start from the stock front. I do not have a image of the old strategy but simply put I was able to add a entry angle and length of the lead in rather than a clearance value. I tried several different settings to see if it would revert and haven't been able to find a way to do so.
I figure this has been updated and will probably have to live with it but if anyone has any advice or suggestions on how to ether revert the strategy or work better with the new one it would be greatly appreciated.
Labels (1)
4 REPLIES 4
@PROGRAMMING7K5CY is this a rest machining toolpath?
Akash Kamoolkar
Software Development Manager
Yes it is @akash.kamoolkar
@PROGRAMMING7K5CY Thanks, we are aware of this deficiency in angled entry in the new profile roughing strategy and already have a ticket for it. For now a workaround for rest area machining with angled entry would be to use the legacy profiling strategy until we fix this deficiency.
Akash Kamoolkar
I see, will work with it for now. Thank you for the quick response as always.
