Announcements
never seen this error before
Hello community,
I have never had or seen this error before.  I tried 2 different posts and it gave the same results.  My triad is in the correct place.  not sure what I am doing wrong.  Any suggestions?  Trying to post some code right now I can't
Thinking more about this..  I isolated this part in an assembly and created the CAM file for this part.  I am wondering if it has to do anything with being an assembly?
I renamed the file and deleted all of the assembly part.  Still getting the same thing.  Grrr.  Here is the files
Steinwerks
I'm not at a computer but dollars to donuts you have a funny hole depth definition in a drilling cycle. Check your depths, look for doubled up heights IE top and bottom being the same value or the bottom set above the top height using an offset.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
daniel_lyall
@Anonymous what @Steinwerks says model top, hole top. hole top is what is doing it
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Yep..  That was the problem.  I had a model top and hole top in the 1st operation.  I made one change and it posts now.
I can't say it enough that this forum is great when it comes to getting solutions.  I use Inventor HSM in a friend shop to program for him and the Inventor HSM forum can hold water to this one!
Thanks for the help Guys.  cheers
