Nesting Issue - Nesting is not showing internal features of the model when exported to DXF
jennyperlasko
Message 1 of 1
jennyperlasko
Hi all,
I have been nesting flat patterns created from sheet metals into plywood successfully but now when I export the DXF file generated from the nesting, it only shows CONTOUR lines and bend lines, so the internal features of the nested components are not showing in the DXF file. I need to have these inner lines for the Manufacturing of Kerfs, so I wonder is it possible to fix this? Can I export not just the contour but a projection of the body with all its internal shapes?  You will see that the DXF does include the bending lines but not the Kerf lines the body has inside. Please see images attached for reference.
Is it possible? I appreciate all the help.
Kind regards,
Jenny
Replies (0)
