Announcements
Need some help CAM a Sign
Hi
Ive made this sign for my daughter, but somehow i cant get the 2d pocket too work.
it seems too create the obly the bottom of the selected surface, ive tried too select the whole sign aswell too make a 2d pocket opperation but it just make a very long od g-code.
Got a internel kernel error when using adaptiv clearing so thats not a option (is adaptiv clearing disabled in studet verson)?
I have attach some img of what i tried too atcheve below.
Thanks in advance for any help.
Kind regards Jan Håvard Brenna
Steinwerks
If you can export the file as a .F3D and share it here that would be most helpful. I'm guessing you have some geometry selection issues, but I'm not very good at diagnosing from these images I'm afraid. Others here are better, though.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Hi.
Thank you so much for looking in too it:)
You are totaly right, there was a geomtry issue in the model. ive used the model as a cut tool in a box. and the i saw the error was quite obvius :slightly_smiling_face:
Wish you the best
Kind regards
Jan Håvard
