Need help with Sheet Metal Pattern
crullier
crullier
Guys what is the best way to get a DXF out of the flattened SM Part for a laser cutter?
It would great to also have the bend lines.
Thank you
daniel_lyall
Does the laser cutter work ok with fusion's .dxf files
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
randyT9V9C
You can also try the AutoCAD DXF post.
http://cam.autodesk.com/posts/?p=dxf
al.whatmough
What laser are you using?  could we skip DXF completely and program the laser in the Fusion 360 CAM workspace?
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
