Fusion Manufacture
Need help with Rotary Contour, stock left
2 REPLIES 2
110 Views, 2 Replies
For the first time I'm trying to use Rotary Contour. But I'm stuck on the last bit of stock that is left on the bottom of the groove. The walls are perpendicular to the groove.
I would love to hear from some of you. F3D file is attached
Thanks in advance
2 REPLIES 2
seth.madore
The issue, in my view, is that the bottom surface isn't planar, see how it dips in?
As this is an imported model, it's uncertain whether this is intentional or not.
However, since you've got the Machining Extension, you might want to try Advanced Swarf (it's a Preference > Preview Feature you need to turn on). This should do a decent job of cleaning up the remaining material:
Seth Madore
in reply to: seth.madore
Thanks for the response. I see it now! it's a strange groove nonetheless. I'll try the advanced swarf!
