Fusion Manufacture
Need help with 5 axis on radius
2 REPLIES 2
ktf3
80 Views, 2 Replies
Hello everyone,
I want to mill a radius with a Ball Endmill and want the Mill to follow the curve.
Ive tried it with the parallel operation but cant seem to get it working with 5 axis, the Mill is just facing the z axis.
Id greatly appreciate of someone could help me find the right settings.
2 REPLIES 2
programming2C78B
in reply to: ktf3
the tool would be stationary, with the workpiece moving?
well need your fusion file
Please click "Accept Solution" if what I wrote solved your issue!
a.laasW8M6T
in reply to: ktf3
Hi
For parallel you will need to use the "To curve" option and make a sketch line along the center of the radius.
There are other toolpaths like Flow,Blend, Steep and shallow, Geodesic that have a "Lead and Lean" option that will make the tool normal to the surface.
see attached example
