Fusion Manufacture
Need Help Milling Pocket Vee--File Attached
6 REPLIES 6
utekcnc
169 Views, 6 Replies
Good Day--I have attached a file with a vee block I'm programming.   I cannot get a clean nice tool path to machine the vee.   I want to use a 1/2 endmill for roughing and then I have a 3/4 ball nose for finishing.   Could someone please take a look at this for me?   thank you
6 REPLIES 6
seth.madore
in reply to: utekcnc
The Parallel toolpath doesn't seem that bad, am I missing something? Is it the fact that it doesn't flow over this edge as much as you want?
Seth Madore
programming2C78B
no need to select your model to Machine. Instead, do this. You can set these to defaults as it'll probably come up all the time. I constrained the Bottom to the lowest level of your trough.
You can also save 30% of the time by cutting the outside with Both Ways contour VS your adaptive and all those wasted jogs, same feed and speed.
Please click "Accept Solution" if what I wrote solved your issue!
utekcnc
in reply to: seth.madore
It's the roughing it out that I cannot get
seth.madore
Your "suppressed" toolpath (Pocket) doesn't seem to be doing that poorly of a job (although not optimal). What is your machine and the material you are working with?
Seth Madore
utekcnc
1018 steel.   Doosan DNM 400
HughesTooling
If you used an adaptive toolpath could you get away with a deeper cut and then a fine stepdown?
I looked at creating overbuilt surfaces to machine past the part. Didn't work too well with the ordinary pocket as it took longer to machine. The adaptive with a bigger (0.3) roughing stepdown and 0.1 fine was about a 1/3 of the time.
See attached file.
Mark Hughes
Owner, Hughes Tooling
