Need help in slowing down tools in inner corners
MetalRipper_
MetalRipper_
Hi guys,
I need help in reducing the feedrate while machining inner corners. There is a feature "Feed optimization" but can't get it to work.
Looking forward for your ideas.
Thanks.
Gokul Kannan
Making Parts at MetalRipper using Fusion 360
Youtube.com/@metalripper-
CNCexpert.com/gokul-kannan
brad_francola
Hi.  I posted your code with a FANUC post processor and it appears to be working.
brad_francola
You may find that using Show Toolpath Data is helpful as you work though this issue.
MetalRipper_
Hi @brad_francola
Turning SMOOTHING ON solved this issue. The yellow lines in the internal corners indicates the feed optimization, which was missing without smoothing.
Thanks.
Gokul Kannan
