Fusion Manufacture
NCStudio 4th axis post problem
4 REPLIES 4
roman_Sholiak
320 Views, 4 Replies
Hi All ,
I have 4 Axis CNC machine with 4th axis installed parallel to Y move , but in controller is A axis .
I add 4th axis and have some movement with it - at least first drilling cycle is correct 🙂 .
But after first rotation - instead of drilling using Z coordinate , I get movements on X axis .
Next rotation of 90* and drilling goes up in Z ( instead of down ) .
Can someone advice what to change in post processor attached ?
Test project also added below .
4 REPLIES 4
seth.madore
in reply to: roman_Sholiak
I took a quick look at the post processor, it looks like it just needs a simple edit.
var tcp = true
Set it to:
var tcp = false
Seth Madore
roman_Sholiak
in reply to: seth.madore
Thanks - it works !
roman_Sholiak
BTW ,
It works not - but only with safe retract as G28 . If I change it to Clearance High - behavior is like before .
But anyway - at least it working 🙂
I tried using the post processor with and without changes , but somehow it both time it failed to generate g code. Telling there the direction is not supported for machine configuration
